Wi-Fi camera remote connection
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
07-06-2024 09:35 AM
Hi
I live isolated rural so use EE 4g home broadband, signal is good as l can see the mast from my window.
Data sim is running through a BT 4g Home Hub router, l have a Wi-Fi camera set up to monitor my Motorhome parked on my drive, camera is a cinnadoD1 (Amazon purchase) and uses the Wansview app to connect to the camera.
Everthing works great when l am at home l can look at the camera to check all is ok no problems.
I visited family at the weekend and tried to access the camera via the app, message reads, establishing a secure channel connection, it does not connect?
l have been told it will not connect because the Router will not allow it to, something about it not having port forwarding?
l am not tech savy at all, could someone confirm if this is the case, have l wasted my money buying this camera that will never work remotely using the 4g broadband system l have.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-06-2024 09:17 AM
Hi @KenB2
Thanks for coming here.
Does the app connect if you try the SIM card in another device?
Do you use the app when at home to view the camera?
Leanne 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-06-2024 09:38 AM
Tried sim in another device (BT mini hub) still not working, yes camera
connects remotely when using app at home.
I have been told l am on something called CGNAT, and that's why it won't
connect remotely when l am out and about, something to do with the ip
address and it being a public and not a private address?
Ken
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-06-2024 08:27 AM
Hi @KenB2
If you give us a call on 150 our tech guides will run through some troubleshooting to get this looked into for you.
- Remotely connecting to my home server via IPv6 pinholes in Broadband & Landline
- EE TV Box Pro losing connection to Remote in TV
- Trying to get an expected delivery date of installation of a Full Fibre Service. in Broadband & Landline
- WiFi 7 Dropping Connections in Broadband & Landline
- Issues with EE wifi connecting to Firestick TV. in TV
