Weird 4g behaviour
JKD2912
This month I upgraded to a 125gb plan I’ve got 98gb left but on apps like x, instagram and snapchat it just doesn’t load as if I’m not connected but otherwise works fine on everything else and it’s very confusing why it would be doing this all the apps mentioned have access to 4g in the settings and even on the websites of the apps it doesn’t load
Northerner
Hi @JKD2912
Log into your EE app or online account and check your content lock as i guarantee it is set, hence the issue you are having.
Northerner
Hi @JKD2912
Which router are you using?
