30-10-2024 07:37 PM
I have two EE SIMs working fine in my Netgear Nighthawk M1. However, when I try to use them in either of my new Huawei E8372H-153 4G USB Wingles, they show connected on the admin page. The blue LED is on, but there is no data up or down, and I cannot ping using the admin tools.
Does anyone know what setting I might need to change to get this working?
Thanks.
31-10-2024 10:26 AM
It's the Profile that matters.
Try IP Type = IPv4 only by noting that default Profile, creating a new Profile & populating it with the noted values (pwd = 'secure') with the changed IP Type. Then making it the Default.
30-10-2024 11:08 PM
@buntonn : Is the APN/Profile set correctly for EE?
31-10-2024 08:14 AM - edited 31-10-2024 08:15 AM
Under Mobile Network / Mobile Network Searching it’s set to:
Support 4G networks- On
Network search mode - Auto
under Internet Connection, setting are:
Mobile network - On
Data roaming - Off
Auto-Select network - On
under profiles I see EE Internet(default), here are the settings for that profile.
Name - EE Internet
APN - everywhere
User name - eesecure
Password - I see 8 asterisks
Authentication - PAP
IP type - IPv4 & IPv6
Please let me know if you need anything else.
31-10-2024 10:26 AM
31-10-2024 04:05 PM
It was the iPv4 only that got it working. Thank you 🙂
