25-06-2025 12:37 PM
I have a great 5G router that works perfectly as plug and play with a GiffGaff SIM card but im an EE user.....
if I use the EE SIM card it doesnt connect 😞 and first I thought it was just the APN settings but that didnt work 😞
I tried selecting the band frequencies EE uses..... that didnt work
I looked at the WAN connection which defaults to DHCP but could be PPoE. I cant find the details for this unless I have "wired" broadband for EE.... any suggestions? fixes? im about to give up and move back to GiffGaff
25-06-2025 12:55 PM
What else could it be? It's certainly not PPPoE as that's for fixed BB.
25-06-2025 12:59 PM
agreed...... but just wont connect 😞 APN is right, frequencies are correct card works in 4G router, GiffGaff SIM works in this router but just wont connect 😞
25-06-2025 01:01 PM
Yes, but what are the other options for the WAN connection?
What are your APN/Profile settings?
25-06-2025 01:04 PM
Only other option is Static IP which im sure its not.....
APN
User is eesecure
password secure
25-06-2025 01:06 PM
Is that all the APN/Profile? Nowt about CHAPS/PAP?
25-06-2025 01:21 PM
Thats all I have....
EE level 3 support have now washed their hands of it...
Router manufacturer also say it works with GiffGaff its not their issue either
