on
24-05-2023
09:50 PM
- last edited on
25-05-2023
08:52 AM
DanielPA
I've been having severe - and I mean SEVERE - speed issues (4G can't get 5G here). I ran some tests (Ookla) from my phone (Android) Mac (M1 Max running macOS 13.4) and iPad (running iPadOS 16.5). This is what I'm currently seeing. It's not consistent (tonight I'm not even getting 20Mbps down). I'm being told that these are "within 4G parameters". I'm autistic and I've timed downloads. Real world download speeds are UNDER 1MB/s. I don't think that's in any way acceptable for £31/month. Not when I've had upwards of 10. This was the speed I had less than 3 weeks ago:
I can't even connect to the Ookla app on my Mac , it can't find a connection. I'm consistently having websites 'timing out' on me because I'm "not connected to the Internet" (I can't even buy food). I'm autistic and housebound and I need a consistently reliable connection. I'm sorry but it is. I can't get landline broadband where I am (LU7) so I'm stuck with mobile.
I'm NOT being fobbed off with "this is within 4G parameters", Up is TWICE the speed of down at the moment. That's not right.
I don't even know if I'll be able to post this.
Any help out there...? Anyone else around here having issues...?
on 24-05-2023 09:55 PM
I've spent ages with various tech support people. There are NO known issues in this area (LU7 near Leighton Buzzard). Apparently I just have to accept **bleep**e speeds. I'm NOT going to be doing that for £31 a month... I'm in poor health and I DO NOT need the added stress.
on 25-05-2023 08:11 AM
Hi @AtheneNoctua,
I'm sorry to hear you're seeing slower download speeds from some sources than you'd like.
It looks like you're receiving relatively consistent speeds when testing, but in real use, download speeds will vary depending on the bandwidth made available to you by the service you're downloading from. You won't always be able to download at your peak 4G speed.
Not being able to access some websites at all is a different issue altogether and I'd recommend contacting our Technical Support Team to report it.
They'll be happy to help 🙂
