TV via Mobile Hotspot
susan154
I would like to use my new Galaxy A53 as a hotspot for small smart TV on my narrowboat. TV connects easily. I tried iplayerbut kept spooling. I have bought a fire stick. Is this likely to be any better?
I suspect the limitation here, be it data allowance or speeds, is the mobile network speed rather than the end-device that is trying to connect.
If one streaming device had problems connecting, changing to another one is unlikely to make much difference.
What sort of speeds are you getting via a speed test on the phone itself?
