using 4gee wifi mini with a new device
Ro26
I use my 4gee wifi mini with a laptop, but I'd like to use it with my phone.  Problem is that I've forgotten the password, and need to know how to change it?
@Ro26 : Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
