Signal booster
Maverick777
I have the EE 4G Internal Smart Hub. Can you purchase and external signal booster to connect to the Hub?
A "signal booster" is a very popular term amongst users in poor coverage areas, but they've never really existed except in some very specialist situations.
WiFi-calling is EE's recommended way of dealing with poor indoor coverage which is - sooner or later - inevitable in some places. Connect your phone to a WiFi-network and enable WiFi-calling in the settings. You can now make & receive calls, send & receive text messages using WiFi as the coverage instead of the mobile network.
10 REPLIES 10
WiFi-calling is the solution anytime you have a working WiFi signal, which your router provides.
What does that mean please?
Your hub provides a WiFi signal.
That allows you to use WiFi-calling on any compatible phone, providing you with indoor coverage anywhere in range of the hub.
@Maverick777 : Signal boosters are no longer supplied.
Consult Check service in your area  to see if any faults are being attended to in your local area.
Maverick777
Would this work ?
BOOBRIE 4G 5G LTE Antenna Outdoor... https://www.amazon.co.uk/dp/B0CTH5TQVV?ref=ppx_pop_mob_ap_share
Does your router have antennae ports & of the required type, 2 x TS9 or SMA, I gather?
The spec lists all of EE's current 4G bands (800Mhz, 1800Mhz, 2100Mhz, 2600Mhz) but only N78 for 5G-NR. The other 5G-specific band you should seek is N28-700Mhz
Sadly the internal router does not have antennae ports. So I guess I need a TP Router….which would you recommend with the option to attach an external booster aerial ?
Thanks.
I have the 4G Smart Hub:-
Do I need something like this?
 https://www.amazon.co.uk/Archer-MR200-Unlocked-Configuration-Removable/dp/B0161ACBE0/ref=rvi_d_sccl_...
To use with external booster aerial
