SIM card for 4g router- how to activate and top up?
LindsayDawson
Hi, I bought an unlimited data EE SIM card to put in a new 4g router. The packaging says it has £10 on it but I’m not sure. It’s is to go in a 4g router as my son has no WiFi coverage. I can’t seem to get any credit on the SIM card, and can’t get the router to work. Any ideas?
Visit http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see your data & credit status as well as its mobile no. at the top. What does it say,  obscuring your mobile no.?
What do you mean by a device connected to the router?
Isn't your son or somebody gonna use it to get WiFi on their phone or some other device?
He’s going to use it to connect to his pc
Then connect that PC to it.
