Re: EE Mini HUb 3397-2 4ghz
btota
how can make my router 2.4ghz
6 REPLIES 6
James_B
EE Community Manager
Hi @btota,
You can change from 5GHz to 2.4GHz by logging in to your router at 192.168.1.1 and selecting Settings > WiFi.
Hope this helps.
julietwade5785
Hi, I can't get my EE mini hub won't connect the Internet. Please help.
Leanne_T
Hi @julietwade5785
Thanks for coming here.
Is the SIM card pay as you go or pay monthly?
Have you been able to connect to the internet previously?
Leanne 🙂
Hi, James,
What Password do I need to Log into my Mini hub to change settings, when I put its password in it rejects it,when I put my EE password in I used to log in here it also rejects it.
Please advise
Mandy
@Ma218 : You need the router's admin password. Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover.
MyEE has nowt to do with routers.
Ma218
Thank you, that makes sense I will have a look tomorrow.
