on 25-08-2023 01:21 PM
Unfortunately I get " password incorrect" if I try this.
Solved! Go to Solution.
25-08-2023 07:40 PM - edited 25-08-2023 07:40 PM
@Missmouse3 : That is the 4GEE WiFi Mini, which for some reason EE has renamed as EE Mini Hub Halo. Something to do with having BT BB Halo? It is eminently capable of viewing & changing its WiFi pwd.
on 25-08-2023 01:22 PM
Tried this! Still cannot get in.
on 25-08-2023 01:23 PM
Same here 😡
on 25-08-2023 01:35 PM
Hi @Missmouse3
Are you using 'admin' as the password?
Have you ever manually changed the admin password on your device? If you have, a factory reset will change it back.
on 25-08-2023 04:20 PM
Hi, just got the minihub. I've tried resetting, using admin as password, using the password as the password, using my by password, using my ee password - all are incorrect I'm told 🤷♂️
on 25-08-2023 04:21 PM
Cannot connect to this hub by cable! Wifi only. It works fine but I'd like to change the password!
on 25-08-2023 04:26 PM
@Missmouse3 : Which mobile router do you have? If you don't know its title post an image of it.
Have you tried factory resetting it by pressing the Reset (R) button for about 10 secs?
on 25-08-2023 04:40 PM
I've just got the minihub. It is connecting my devices fine but I just want to change the password. I've tried a reset, I've tried admin, I've tried the password, ivf tried my BT password, I've tried my EE password, all , I'm told are incorrect. There is no " forgot password" option tho!
All I want is to change the password to something I want!
Can't understand **bleep** they make this fo bloody difficult!
on 25-08-2023 04:54 PM
@Missmouse3 : You're making it difficult for us to help you. There isn't an EE mobile router called "minihub" but you won't tell or show us just which 1 it is.
on 25-08-2023 05:05 PM
this is it. I messaged BT on FB Messenger & have now been told it is not photo change the password on this minihub 🤷♂️
