PAYG sim abroad
deecee22
I have an EE mini wifi modem that I have used for over a year. Can i buy an EE data sim card in the UK for use in Europe. I am unlikely to be able to buy a local data sim card where I am travelling as advised by travel blogs.
Schockwave
Hello @deecee22 ,
Welcome to the community,
If you buy an EE pay as you go SIM card in the UK, you will have to make sure that you activate and use it here in the UK before using it abroad. Just bear in mind, depending where you go abroad, it could turn out to be expensive, although Europe should not be too bad, I would suggest checking the cost of data and where possible, use wifi when available, there should be no reason why you cannot use it abroad, but must also make sure that you have enough credit for use abroad.
Schockwave
Hello @deecee22 ,
