11-06-2022 09:51 PM
My 4gee ee mobile board band box has all the light on green, but I camt connect any devices to it, I can't even log on to the http bit
11-06-2022 10:07 PM
All it says couldn't get ip adress when trying to connect t
12-06-2022 09:01 AM
Could you try restarting the router please, @amieeajs?
There should be a pinhole on the back to reset it.
12-06-2022 09:21 AM
Already done this just done it again and still nothing
12-06-2022 09:54 AM
Are there any maintenance works in your area, @amieeajs?
You can check on our network status checker. You can report problems on there too, so our network team will investigate.
12-06-2022 10:26 AM
No known probs in the area
12-06-2022 10:33 AM
12-06-2022 10:45 AM
That me
