23-05-2022 04:32 PM
Hi, I recently moved into an older apartment building and after having previously been a Virgin Media broadband user in my previous home, I found that unfortunately, their services weren't available for my new address. I looked around online for the best speeds and found out that EE offered the best speed for the best price and as an EE mobile customer, I decided to go to my local store and spoke to the team there about my dilemma. They confirmed the landline speeds for my new address would be in the 3-6mbps range, but suggested I instead opt for a new 5GEE Wifi Router as it instead used the mobile network rather than the landline and checked the speeds for my area. They said that I should expect speeds of up to 140mbps, which was higher than my previous package with Virgin Media and at a cheaper price too, which I immediately took them up on as it sounded too good to be true. Unfortunately, it seems to have been the case.
I set up my router as instructed, using my laptop to test it with as I'd not yet had time to set up my home computer. My initial speed was 72.6mbps download and 11.6mbps upload. Not exactly 140 I thought to myself, but it was still very good, so I had no problem with it. I then go to sleep for the night and wake up to find that my router turned on for about twenty seconds and then once it achieved connection with the internet, it'd turn itself back off. I called technical support at the time and after they attempted to troubleshoot my router, eventually deemed that the battery must be faulty and that I should take it back to my local store to have it fixed or replaced. I did just that and they found the same problem and were not able to fix it, so instead sent off for a replacement. Two days later, I'm informed my new router has arrived - I go to receive it and have them set it up and make sure it works in the store before I took it home. At home, it works fine, at roughly the same speeds as before until about six hours down the line at which point it turns off again and has the same problem. I go back to the store and they give me a different charger to try and it seemingly works fine from then onwards in terms of battery, albeit with a consistently blinking battery light.
Now, I finally get my home computer setup - I'm an avid PC gamer using discord, youtube, twitch, steam, etc - and to hopefully ensure I have the best connection possible, I used an ethernet cable. This, however, seemingly has been the worst decision I've made. My speed tests come out with 6.79mbps download and 3.27mbps upload at best - quite literally what I could have had on landline-based broadband. To make matters worse, I would randomly get ERR_CONNECTION_CLOSED errors on Chrome when trying to browse, found myself unable to connect to Steam at all, and when it came to Discord I found myself with 9999 ms and a packet loss rate of 100.0%. Weirdly, I could hear others relatively fine with occasional cutouts but they couldn't hear me at all, and I could join discord screen share live streams, but couldn't do it myself too. So, I googled it and found a thread on this board by @dan-giddins which seemingly perfectly described my issue, and followed his solution which worked, enabling me to use the internet again, however with the persisting low speed and a rough ping of 50-100ms.
I decided to check my speeds again on my phone and laptop - both connected via wifi - and my laptop came back with a download speed of 21.7mbps and an upload speed of 5.81mbps while my phone came back with a download speed of 23.2 and an upload speed of 4.23. I tested discord on my laptop and found I received roughly the same ping as my desktop. So, this led me to possibly think it could be something to do with my connections being on the 2.4GHz connection over the 5GHz. The only problem is that the 5GHz only appears on my phone, and not my laptop and I have no idea how to pick which it uses on my ethernet connected computer. So once again, I googled it and it led me back here, where I was unable to find an up to date solution outside of supposedly changing the level of security. So, I gave that a shot and tried every type of security on the 5GHz - even disabling security entirely for a little bit - and nothing changed, the 5GHz wouldn't appear as a network on anything outside of my phone.
Lastly, on the admin control panel, it displays my router's connection as 1-2 bars at all times, despite being against my window. I'm also not in a rural area, I'm quite literally next door to my local EE store in the middle of my town centre, so a part of me wonders if this has anything to do with my ping and connection issues.
I know I've written a lot, so to summarise or to allow people to quickly see what issues I have and what I've done to resolve them thus far;
I'm pretty sure that's all of my problems so far, if I'm missing any I'll reply later on if/when I encounter them again. Hope this helps others and hope I get some answers. Thank you for your time if you read this and attempt to help.
19-05-2023 04:00 PM
Putting the mistake of determining the relationship between processor speed and gig hertz are related aside.
I'm having almost the same irritating issues;
1) Switching to favour the 4g network has been successful in restoring the speed of the connection to around 108mb, latency is low around 30ms I can live with this. (I have a background in IT so this seemed obvious to try).
2) I have my router wired to all devices; tv, computer that are capable; with my phone on wifi.
I randomly end up with no internet connection on my on my PC all attempts to use any browser (chrome, firefox, opera) and zoom result in a connection reset error; But can ping google DNS 8.8.8.8 via PC fine same on my phone (I have pinged with google.co.uk to test DNS resolve), the speediest route to getting a fix is to restart the router, note that my pc/phone/firestick do not need to restarted.
So with my support hat on the common factor is the router in all of this;
The box is new-ish about 6 months old and has the latest firmware installed.
What has been tried to fix;
The network troubleshooter on Windows PC has no effect.
Standard netsh and ipconfig solutions have no effect.
Changing the DHCP lease from 24 hrs to 7 days has no effect,
Explicitly restarting PC has no effect.
I'm really reticent about a full factory reset as the issue is not one of a misconfigured device, because I have not played with the advanced and a power cycle fix's the issue, it feels like software to me and irritatingly the system log is pathetic, only connections to the box and start of wifi are logged.
To boot my friend who lives about 10 minutes away is have the exact same set of symptoms.
If this is a bad batch issue it's been two years since this was raised.
One last thing the battery light with start to flash at least once (for a period) a day, the device is plugged in at all times and is powered 24 hrs a day.
19-05-2023 04:15 PM
Hi @crazeydave,
Our Technical Support Team will be happy to look into this issue if you get in touch.
20-05-2023 02:45 AM
I'm not a EE phone customer is there a 0800 number for support?
20-05-2023 02:55 AM
@crazeydave : Try calling CS on +44 800 956 6000 (option 2 > option 4) . That won't ask for an EE mobile no.
However if you are enquiring about an EE mobile router or even EE SIM you do have an EE mobile no. & are entitled to call as an EE cust.
11-06-2023 11:09 PM
A new symptom, I lost my internet connection, I noticed as Firestick stopped working,
I looked at the 'mobile' box and my internet connection light was off.
I wanted to perform a software restart of the router, to try and determine the reason for the problem is it software or hardware?
The first attempt to connect to the device via the 192.168.1.1 via my phone resulted in an ERROR_CONNECTION_TIMEDOUT.
I managed to connect to it via the PC but it was painfully slow to load the landing page.
I attempted to log in, but after quite a period of time, it showed a simple ERROR message above the login password box and did not continue.
A power cycle fixed the issue, but it's very frustrating that the logging for the device does not give any real information about the device, considerably less than every router I have ever used (and that's a few).
I find it hard to believe that level of logging offered is all the device can produce.
11-06-2023 11:29 PM
@crazeydave : Which router do you have? Router logs are rarely much help, other then telling if & when the BB is up or down.
12-06-2023 10:34 PM
It's a Type: 5GEE Wifi Model: QTAD52E SKU 300022250.
It's a mobile device but is not moved, powered all the time.
It's cable'd in for everything except for my phone which uses Wifi, using a no-fuss Netgear switch.
It's currently the DHCP for the network for a total of 4 devices (with a lease time of 7 days, changed for 24 hours to see if a failure to renew was a problem).
Below is a list of the latest entries (which is the same as every other time I've looked).
It's basically the '5GEE WiFi started'. which is a reboot and an indication of the time when I connected to the web front end.
As you can see from the '5GEE WiFi started.' entries this is a persistent problem for me.
On the logging, I would expect to have at least some more information regarding the DHCP, at least.
Time Event
12/06/23 22:12 | Login successful from 192.168.1.49, 34:17:eb:a1:c3:bd, DESKTOP-6A0C64V. |
11/06/23 22:46 | Login successful from 192.168.1.49, 34:17:eb:a1:c3:bd. |
11/06/23 22:45 | 5GEE WiFi started. |
29/05/23 19:29 | 5GEE WiFi started. |
28/05/23 11:57 | 5GEE WiFi started. |
25/05/23 13:09 | 5GEE WiFi started. |
24/05/23 12:03 | 5GEE WiFi started. |
22/05/23 01:50 | 5GEE WiFi started. |
22/05/23 00:11 | 5GEE WiFi started. |
19/05/23 14:47 | 5GEE WiFi started. |
