No Access to wifi controls
KwameShark
There is no interface on the EE app to access the speed of my 5G EE hub.
1 ACCEPTED SOLUTION
Alex_H
Hi @KwameShark,
Welcome to the EE Community
The in app Wi-Fi controls are only for those on EE Fibre Broadband. For 5G mobile broadband you can access your router settings by visiting the admin page at http://192.168.1.1 on your browser. The login details will be on the keep me card with the router and also printed on the bottom of the router.
In terms of checking what speed you are getting you could check using a speed test service such as  Speedtest by Ookla - The Global Broadband Speed Test or Internet Speed Test | Fast.com
Alex
Alex_H
Hi @KwameShark,
Alex
