Mobile Broadband
Tety
I have a 4g mobile router and I have a question if I can get a router like this but bigger with Lan ports? Because I need a connection to a personal computer and a stable one.
Before I lived in another flat and I have no possibility to change my contract and I was sent a small smart router. In general it fits but I want to know if it is possible to get the same one with Lan ports?
Peter_W
Hey there @Tety.
Welcome back to the Community 😊
Based on what you've mentioned here, our 5G Smart Hub sounds like it'll be the best shout.
This is designed to be used in place of a wired home connection, and features 1x 1.0 Gbps GigE port, and 1x 2.5 Gbps WAN port for wired connections too!
Peter
Peter_W
Hey there @Tety.
Peter
I was given a free smart hub due to a company error, basically the question is whether they can send me a figuratively similar smart hub but with a Lan port. I also continue to pay for internet but I don't have it.
Can I know 100% what my minimum speed will be? Because there is no 5g connection where I live.
Rach_H
We wouldn't be able to give you a guaranteed minimum speed for the 5G router, as this would depend on the area you are using it in @Tety.
It might be worth checking out our full range of routers, to see if any of these would fit what it is you're looking for.
Rach
