mobile router
Afc89
hi there iv got a mobile router Im going to put a sim in it From ee that I got from the shop got a phone number and that .what I would like to now do I just put the SIM card in and away it goes or will I have do activate it or something when I put it in .
1 ACCEPTED SOLUTION
@Afc89 : You will need data for it to go on the Net. Did you buy the SIM with a plan or a data add-on?
If not, you will need to visit http://add-on.ee.co.uk/purchase from a device connected to your mobile router by WiFi to see what data add-ons are available. This is also where you'll need go when your current data expires.
