EE 4G WiFi
StuartDuff
I currently have an EE 4G router,  the WiFi seems to be dropping off and causing dead spots. So, im looking for an option to boost WiFi signal in the house and possibly the outside shed. It needs to be a simple install as im no techie.
Whats your thoughts, and help gratefully received.
Thanks Stuart
Christopher_G
Hi @StuartDuff
Welcome to the community.
If you haven't already, I recommend trying to move your router to another part of the property. Also - Have you looked up WiFi extenders? You'd need to find one that's compatible with your 4G router.
