Netgear MR5200 connection issues
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-10-2023 05:29 PM
Hi all,
My Netgear MR5200 has stopped working and now displays the message ‘Mobile Broadband disconnected’. I have 2 EE SIM cards and have tried both in the device but still won’t connect. Both the SIM cards work fine in my phone so it must be something with the device settings.
I have checked it’s the right APN network it’s connected to l, and have fiddled around with some of the APN settings, all haven’t worked. I’ve done a factory reset but it still doesn’t work.
any help would be greatly appreciated 🙏
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-10-2023 12:23 PM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-10-2023 05:16 PM
Hi Chris,
Thanks for the reply!
yep those are the APN settings that are being used at the moment.
I’ve tried changing various APN settings but to no avail.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
17-10-2023 08:07 AM
Thanks for checking @Lauraharrison1
Our Technical Support Team will be happy to run through some diagnostics with you if you get in touch.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
17-10-2023 03:35 PM
There is normally a setting within Netgear Mobile Routers that allow you you to discount the Radio Modem Connection but still run the Router for normal Local Device use, this setting can sometimes default to Off, especially when swapping Sim Cards.
I don't have a Netgear Router or any documentation now and all this was from a few year back but from memory it was a Setting called something like Cellular or Cellular Data Connection (On / Off), this Setting (its in there somewhere) should be available in the Admin Web UI or any of the Netgear Apps.
If the above doesn't help there is also another setting for Domestic Data setting which allows you to switch between Cell Modem Data or Internal Domestic Data ie, Broadband etc, but my money would be on the setting above.
- EE fibre 1.6gb connection and speed issues in Broadband & Landline
- Poor Ethernet and Wi-Fi Connection with 5G Mobile Broadband Router in Mobile Broadband
- Every 15-20 mins - Broadband issue message in TV
- Ongoing Broadband Service Failures & Request for Compensation in Broadband & Landline
- FTTP not installed today - Help in Broadband & Landline
