Mobile broadband vs fibre
JMG94
Hi all,
Hoping you can help!
Fairly new to EE (still awaiting my sim for my mobile). After a bit of advice around broadband and 5G mobile service. My current home broadband provider (Talktalk) provides a “fibre” service (only up to 65mbps download) - this is “guaranteed” at 55mbps but am getting no where near this! After lengthly troubleshooting steps, it turns out that minimum speeds (55mbps) is “guaranteed” when up to 5 devices are connected simultaneously…
Pretty much, I’m looking into mobile broadband in my area as EE offer 5G mobile data service in my area (Vance why I have swapped to them from 3 - even worse service on mobile data at home!). Am I better off buying a 5G router and 5G EE data sim in place of my “fibre” TalkTalk broadband? Is there better bandwidth for 5G data over a fibre connection? There are no internet service providers in my area that offer speeds greater than 70 Mbps in my area at the moment - I think I’ll have the same issue with them as I have with TalkTalk…
Not 100% sure where/if to start. All that I know is, I’m unable to use my home broadband effectively as have quite a few “smart” devices at home: laptops, TVs, smart switches, phones, iPads, lights etc. Hence a really slow speed…
Any advice is greatly appreciated!
The speed of your fixed BB connection is not dependant on the no. of devices using it. It is just shared out between them, whatever it is.
  • For non-EE routers: login to it according to the label on it as the admin user & navigate looking for its router/connection statistics.
