Mobile Wifi extension lead
MollyC
Hi,   I have the EE mobile wifi box but the lead is too short, Is it possible to get a longer or an extension lead?
14 REPLIES 14
Yes it is, but you will reduce the Life of the Battery if its permently On Charge, also keep an eye on the Device does not get too hot (ie, over heats, good Air ventilation) removing the the rear Battery Cover may help with this slightly.
Thank you again  🙂
@MollyC   If the device gets hot turn unplug it.  The device getting hot is the battery get hot because it will degrade faster if left on charge.  Battery powered devices really shouldn’t on charge once they are charged up as it reduced the life time of the battery.   Think of your device as a mobile phone you would leave that on charge for long periods as it’s not good for the battery.
Thank you, the prob with this box is the charge doesn’t last very long
What you want is a USB-A to Micro USB cable of whatever length you need. You'll find plenty on Amazon et al.
