EE5G Router 2022 External Antenna Configuration
mcflow
1. The EE 5G router has 4 ports in the back. I believe it to be a white labelled Zyxel NR5103.
2. The external antenna I am trying to connect is a Poynting 4x4 Omni directional. Cables are labelled Cell 1 Main, Cell 1 Aux/Div, Cell 2 Main, Cell 2 Aux/Div (4 cables with TS9 male adapters).
Q: What is the correct cable to router port mapping for optimal results?
1 ACCEPTED SOLUTION
EssexBoyEE
@mcflow  as follows is the correct order for the Poynting 4x4 Mimo Antenna and your Router -
Pair 1
Router Port 1 - Cell 1 Main
Router Port 2 - Cell 1 Aux/Div
Pair 2
Router Port 3 - Cell 2 Main
Router Port 4 - Cell 2 Aux/Div
A similar topic on your Router and some different Antennas was discussed recently on another Thread which you may find of interest here -
https://community.ee.co.uk/t5/5G/5gee-router-which-antenna/td-p/1124775/emcs_t/S2h8ZW1haWx8dG9waWNfc...
EssexBoyEE
Pair 1
Pair 2
TheGrownUpGeek
Sorry to ask a silly question but is port 1 the highest antenna port on the router?
