18-11-2022 03:53 PM
Hi. Have a 4GEE Wifi mini device for holiday home in Cornwall. Turned device on when we arrived earlier and it has charged up. However, the red light appears on the signal indicator and when trying to connect devices state no internet.
Mobile phone is EE and has good 4G signal.
We have 75.6 GB left of 120 GB so still have data.
Have reset with button inside device (held down for 10+ seconds) and also held power button down... momentarily all lights are blue, then mail turns off and signal goes red 😞
Any advices will be gratefully received.
18-11-2022 07:07 PM
Are any EE mobiles working OK? They use the same network signal, that would be a good test.
If not, I'd suggest using "check status" on the online coverage tool
18-11-2022 07:11 PM
I haven't used a MiFi device since 2015 when I used it with an EE Sim. If I recall back then I just popped the sim in, turned it on and it worked.
I assume you don't have to enter any of the APN settings (Network settings)? They're usually found on the plastic wrapper/packet that the SIM card is shipped in, on the label, or sometimes inside the packet.
18-11-2022 09:28 PM
Other EE mobiles are OK.
Checked status and no adverse issues.
Took Mini out for the evening and had same issue ;-(
18-11-2022 09:31 PM
It is strange, device worked fine 3 weeks ago and now keep getting red light for signal.
19-11-2022 09:00 AM
Hi @Dizbeans,
If you swap the SIM cards between your phone and your router, do either connect to the network?
19-11-2022 05:03 PM
Thanks James
Had not thought of that. However, have taken device to EE in Truro and sent for repair / replacement.
Now we wait & see.
Thanks again for responses.
20-11-2022 08:36 AM
Please keep us updated @Dizbeans
