Managing sim in mifi device
Kak13_
How do I see data left on a SIM in a mobile wifi device.  When I try to link the number , I need to verify with a code sent to SIM number,  but it's in a mifi not a phone, so I can't retrieve.
  1. Visit http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see your data & credit status as well as its mobile no. at the top.
  2. Most mobile routers can receive texts. Login to it & look for the SMS Section/Inbox.
Thanks but that link doesn't work.
Katie_J
Hi @Kak13_.
Are you able to try taking your SIM out and putting it in your phone to receive the code?
Katie
Make sure that you are using HTTP: in the link and not HTTPS:.
