Lost security passcode
Micmac9472
What passcode? Do you mean the WiFi password to connect devices to your mobile router?
Jleput
forgotten mobile login passcode
@Jleput : On the assumption that you mean the WiFi pwd, Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
