on 02-06-2023 09:52 AM
I have the 4GEE home router connected with a 4G antenna fitted on the roof of the property with strong signal strength and the past week the internet connection will randomly drop for 2-5 minutes at a time impacting work from home.
This seem to have been consistent since the service issue within our area (PE16 6BG
*****Device details: *****
Device name: 4GEE Router
Software version: 4GEE_Router_V01.06
*** More details ****
Network name: EE
Network type: 4G
RSRP: -75 dBm
RSSI: -47 dBm (-40 to -50 depending on outdoor conditions)
Band: 3
LTE Cell ID: 5597953
Tested this across many devices including:
- Desktop PC wired on lan
- Smartphone with other network
- Smartphone with another EE sim
- Wifi smart Devices
As aforemention, the problem we have is that the internet connection will just randomly drop for a few minutes at a time, any time of day, there doesn't appear to be other symptoms, this has only appeared to happen since the service issue in our area recently.
The logs from the 4GEE router itself doesn't appear to be helpful but will indicate how often it drops with the time between each time my work laptop connects to the router.
02/06/23 09:47,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
02/06/23 09:33,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
02/06/23 09:20,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
01/06/23 22:17,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
01/06/23 14:48,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
01/06/23 13:04,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
01/06/23 12:10,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
01/06/23 12:03,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
01/06/23 10:00,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
01/06/23 09:57,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
01/06/23 09:10,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
01/01/21 00:00,4GEE Router started.
31/05/23 17:21,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
31/05/23 12:47,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
31/05/23 12:43,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
31/05/23 09:40,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
31/05/23 09:38,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
31/05/23 09:20,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
31/05/23 09:17,Login successful from 192.168.1.3.
30/05/23 15:23,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
30/05/23 10:16,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
30/05/23 09:55,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
30/05/23 09:13,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
30/05/23 09:07,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
29/05/23 17:44,Login successful from 192.168.1.77, 7C:21:4A:4E:CF:46, LT-883WMN3.
29/05/23 16:14,Login successful from 192.168.1.77, 7C:21:4A:4E:CF:46, LT-883WMN3.
28/05/23 21:15,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D.
28/05/23 21:12,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
28/05/23 16:55,Login successful from 192.168.1.77, 7C:21:4A:4E:CF:46, LT-883WMN3.
28/05/23 16:33,Login successful from 192.168.1.77, 7C:21:4A:4E:CF:46, LT-883WMN3.
28/05/23 15:05,Login successful from 192.168.1.77, 7C:21:4A:4E:CF:46, LT-883WMN3.
28/05/23 14:08,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
28/05/23 09:25,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
28/05/23 09:24,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
27/05/23 22:26,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
27/05/23 21:58,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
26/05/23 16:00,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
26/05/23 09:21,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
25/05/23 16:44,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
25/05/23 12:47,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
25/05/23 12:30,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
25/05/23 11:54,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
25/05/23 10:26,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
25/05/23 10:25,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
25/05/23 09:57,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
25/05/23 08:57,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
25/05/23 08:52,Login successful from 192.168.1.81, 6A:FC:9F:F4:7A:A5, LlenardIphone.
25/05/23 08:38,Login successful from 192.168.1.81, 6A:FC:9F:F4:7A:A5, LlenardIphone.
25/05/23 08:30,Login successful from 192.168.1.236, 8A:3E:49:FB:D2:73, Llenard_Iphone.
24/05/23 22:08,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
24/05/23 22:05,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
24/05/23 22:04,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
24/05/23 21:59,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
24/05/23 17:48,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
24/05/23 16:45,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
24/05/23 15:05,Login successful from 192.168.1.80, 6A:FC:9F:F4:7A:A5, LlenardIphone.
24/05/23 10:15,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 23:40,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
23/05/23 21:18,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
23/05/23 20:13,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
23/05/23 19:17,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
23/05/23 19:16,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D, LlenardsRig.
23/05/23 16:28,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 16:10,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 15:48,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 14:47,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 14:37,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 14:00,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 12:16,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 12:12,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 12:07,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 11:48,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 10:39,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 10:03,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 10:02,Login successful from 192.168.1.80, 6A:FC:9F:F4:7A:A5, LlenardIphone.
01/01/21 00:01,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 09:54,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 09:52,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 09:50,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 09:47,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 09:23,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 09:17,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 09:13,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 09:09,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
23/05/23 09:03,Login successful from 192.168.1.3, 08:92:04:54:F0:76, Dell work laptop.
22/05/23 16:01,Login successful from 192.168.1.81, 6A:FC:9F:F4:7A:A5.
22/05/23 15:45,Login successful from 192.168.1.227, B4:2E:99:ED:68:5D.
on 29-06-2023 04:30 AM
Hi, I have been seeing exactly the same issue with my 4GEE router in recent weeks.
I have logged many faults through the EE app and they never find a fault.
I have spoken to EE 2nd level support last week and they insist that there is nothing wrong with the mast , they say as the issue is load related and recommend an external antenna.
I have relocated the router to a different room and managed to get 3 bars of signal, but still our downlaod speed varies dramatically (between 15 and 40 mb/S) . when working at home it still sometimes freezes for one or 2 minutes which is so frustrating..
Our signal is somewhat marginal, on my phone in installed "network cell info lite" and the needle is always in yellow .
RSRP: -100 dBm at best.
I have ordered and external antenna (not from EE) which I will put on the chimney. that will surely help the signal strength.
But I also think that the intermittent "freezing" issue may well be the router itself, possibly overheating. The case does feel hot.
Next week for my one day working from home I am going to position a fan right next to the router blowing into the cooling holes at the rear. If that helps I will keep with the fanon hot days or buy replacement unlocked router such as the tp-link (draytech) MR6400
I hope that helps , good luck with your issue.
Steve
