on 29-01-2023 04:30 PM
I have a 4GEE WIFI MINI which ive had a long time. Not used it for a while but going away in a couple of weeks, so charged it up and went to top up/ look at what data is left (there should have been around 80gb but i understand theres a time limit) and nowhere on the site recognises the number?
When i call through for help its wanting an EE number punched in, but keeps saying the number isnt recognised?
Any help would be greatly appreciated.
Thank you
Solved! Go to Solution.
on 29-01-2023 04:35 PM
Sounds like your PAYG SIM has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
You needed to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
on 29-01-2023 04:33 PM
Where are you getting its mobile no. from?
