on 29-03-2023 06:42 PM
I have just received my new 5G Smart Hub. My original antenna has 2 SMA connectors but my new router has 4 TS9 connectors. Is it ok to just fit splitters to the existing SMA connectors like these?
And does it matter what order they are connected?
on 30-03-2023 07:48 AM
Hi @Davemog3
I don't see this being a problem, but if you'd like to get a definitive answer, I'd recommend speaking with our Tech Gurus.
Jon
on 31-03-2023 09:26 AM
Does it matter what order the 4 connectors are in there is nothing in the instruction manual regarding external antenna connection?
on 31-03-2023 12:54 PM
Hi @Davemog3
I'm not sure this is something that we can support you with. It may be worth checking with our technical support team.
on 31-03-2023 01:41 PM
My advice would be do not use Splitters (there not Splitters there 2 lots of Coax Cable shorted together), there's a reason the Router has 4 Antenna Connector Ports.
Get a decent 4x4 Mimo Antenna or use 2 lots of 2x2 Mimo Aerials for the job in hand and for the correct Frequency Bands required.
on 31-03-2023 10:48 PM
Thanks for the replies, I have tried the splitters seeing as i had already ordered them. I have gone from 16mb/s on Three through the antenna to 25mb/s on EE with no antenna, I am now getting 55mb/s on EE since I connected the antenna using the splitters. I'm happy with that for now, maybe I will try connecting a 4x4 Mimo antenna at a later date to see if I can get mor speed.
