11-06-2025 02:16 AM - edited 11-06-2025 02:18 AM
I have just bought myself a new drone and want to use my old EE71-2BE8GB3 to connect to it when out on the North Yorkshire Moors
As it's a few years old I've gone and forgotten the admin password for it - is there a way to reset this unit back to factory default settings?
Do I have to get it unlooked for 'others' sims as I don't yet know who's sim card I'm going to use in it.
Thanks for your help
11-06-2025 11:20 AM
@SpeedySalsar2 : When you remove the battery cover there is a Reset button at the top of the battery that you can hold down for 10 secs or so to Factory Reset it.
When did you buy it?
11-06-2025 11:20 AM
11-06-2025 02:27 PM
Thanks for your reply but sorry there is no reset button - just the on/off button on the outside
I didn't buy it, it was gifted to me about 4yrs ago. I've looked on the EE website and there isn't anything like it available now.
Pity as I get a good Wi-Fi signal out of it, I just wanted to be able to change the SSID and access password on it.
Is there a way to upload photos of these things?
Oh good grief!!!! I was about to press 'reply' when I saw the reset button - I had been thinking it was a tab that kept the battery in place
The fact that it had an R next to it had been escaping me for months.
I can't thank you enough for your help, you truly are a star
11-06-2025 02:46 PM
Oh, good! You had me worried as I have 1 here. It's called the 4GEE WiFi Mini.
11-06-2025 09:14 PM
11-06-2025 09:49 PM - edited 11-06-2025 09:50 PM
You can just apply for unlocking by using the Unlocking your device form and giving its IMEI no., which you can find amongst its System Settings. You'll need another network SIM to complete the unlock.
12-06-2025 03:16 PM
