Phone scam
kellyseyeno1
Some scammers nearly managed to order a phone from my account.
They knew a lot of personal information which I never divulge, including the value of my latest bill, the last 4 digits of my bank account no., my sort code and address etc. It started as a call to inform me that my SIM needed replacing and finished with the information that they would be sending, as a gesture of goodwill for the inconvenience caused, a top of the range iphone on a discounted plan which I could send back if I didn't want to take up this offer. Despite my protestations they were insistent that it would be sent to my address (presumably with the intention of intercepting it or getting it back by some other means).
I have cancelled the order and reset my account. However, while I am confident that there has been no breach of security from my end, so I have to ask EE how did you allow a third party to access my account and the personal information it contains?
Ritu_D
Thanks for coming back to me @kellyseyeno1
You can check Numbers EE partners will call from here.
In regards to how information was gained, we have no way of gathering that information here on the community. I appreciate how concerning this must be. If you do not see the number that called you on the link above and you have more concerns, I would recommend Contacting our guides and they can check over your account.
Ritu
What no. was the call from?
Ritu_D
Hi @kellyseyeno1
Thanks for reaching out here on the community.
I can completely understand why this would be concerning, particularly as the caller appeared to have access to personal information relating to your account.
You've already taken the right steps by cancelling the order, resetting your account security, and remaining vigilant. If you haven't already done so, we'd also recommend monitoring your bank accounts and credit records, and reporting the incident to Action Fraud.
Here is some further information on how to Avoid Scams
Ritu
It was a 0203 number. Normally I ignore numbers from callers I don't recognise but I didn't this time and the fact that the caller had access to my personal information (they were already in my account) probably led me to lower my guard and trust the caller more than I should have done. This doesn't alter the question about how they gained access to my account in the first place.
Ritu_D
Ritu
