07-10-2025 12:09 PM
08-10-2025 01:44 PM
I appreciate this isn't ideal at all @crakayl
I recommend you Fill out our complaints form about your overall experience, and a dedicated member of the team will reach out to discuss your concerns directly within 7 days. They'll be able to review everything so far and give you the best advice.
Linzi
07-10-2025 12:17 PM
EE mini router 4g has not been working recently with intermitting connection problems, although my 5g sim in my iphone is working great, after phoning EE support and being told to try putting my phone 5g phone sim into the mini router to try that as a solution which didnt work, i now find my mini router 4g does not show up as a wifi option on my tv or laptop. any help would be appreciated.
07-10-2025 12:45 PM
Hi @crakayl
Have you tried resetting the router.
07-10-2025 02:51 PM
Yeah tried that, thanks for your input.
08-10-2025 12:22 PM
Hi @crakayl
I'm sorry to hear that you're no further forward with this, and I know you'll be eager to get everything sorted.
After our team suggested you try your phone SIM in the mini router, and this didn't work, did you contact our team back to let them know?
If you haven't, I'd suggest this as the next step so the team can continue with any technical diagnostics. I'm confident they'll be able to help further.
Linzi
08-10-2025 01:14 PM
Hi Linzi, yeah EE contacted me yesterday and now want me to send the router to them so they can diagnose what's happening. This will have been the second time I have had to send the router back to EE in less than a year I work from home most days and find this situation intolerable with intermittent Internet for £50 a month. I can't wait until September next year or if sooner to get some money together to end this contract with EE. Thanks you for reaching out though.
08-10-2025 01:44 PM
Linzi
