17-11-2026 12:04 PM
Switching on my bt pro box this morning, i noticed an issue, BBC1 BBC 2, ITV,CH5 were not showing, also issues with the TNT Sports channels, i switched box off and on, no solution, reset the box, same problem, then restarted the router, same problem, keeps coming up on the screen,as a Broadband issue and IPC 6023, all the apps on the box are working, just issues with a load of channels, anyone have any ideas? Many Thanks.
17-11-2026 12:14 PM
Have the channels come back yet? If not, please check for software updates from the settings menu.
I suspect your broadband backup kicked in, as it looks like your broadband cut out earlier this morning. During that outage, the TV Box checked for software updates - when on the broadband backup, the TV Box reverts to basic service and removes the IP channels. Now that your broadband is back online, a software update check will force it to restore normal service.
17-11-2026 12:53 PM
Hi, Thanks Darren, I have checked for a software update, just says i am up to date, channels are still the same, black screen then a message to say there is a issue with broadband, like i said, apps are working, Now TV, Youtube etc, just a lot of HD channels only have a blank screen, TNT Sports comes on before a message stating broadband issues again, i also have EE Smart wifi hubs, which are flashing blue/orange at regular intervals, suddenly struggling to get anything to pair/connect.
17-11-2026 12:57 PM
The 2 Smart wifi hubs have now both turned aqua, still same problems i mentioned with the tv channels though.seems mainly on the HD channels and TNT.
17-11-2026 12:59 PM
Is BBC 1 visible in the TV Guide?
And do ANY of the channels work? Or is it only some channels that fail with the error?
17-11-2026 01:18 PM
Yes it is visible in the guide, as is the message in the corner of the screen to press green to restart programme on iplayer, just with a blank screen, seems to be BBC 1/2, all ITV CH5, Five USA, was watching UKGold, before that froze and the Broadband error message appeared, same with NowTV channels in the guide, and TNT, watch for a little while, freezes, then error message.
17-11-2026 03:06 PM
Your TV Box Edge is showing a poor wifi signal, but your TV Box Pro is showing full strength. Your wifi stats are showing a lot of external interference from other wifi networks though, so the quality is poor. Your router has changed many times looking for a clear wifi channel, but always struggles. It's changed again this afternoon to a channel with minimal interference, but it's a smaller channel so less data can get through.
My first recommendation at this point would be to reboot the router again, to force it to try to find another channel.
It's worth also mentioning that you have 2 extenders, but one of them is currently redundant - nothing is connecting to it. If you moved the extender with serial number ending 6014 to directly next to your TV Box Pro and then connected the ethernet cable from extender to TV Box, it would eliminate any wifi quality issues to your TV Box Pro.
17-11-2026 03:15 PM
Thanks for all your help, channels seem to be working much better at the moment, and thanks for your advice, will action what you have said ASAP, many thanks again, all the best.
