EE APN applied, connected but no data
ChrisMinto
Hi, hope someone can help
I have a contract EE SIM (tested and working in EE modem).  I've put it in a Teltonika TRM240 USB modem with aerial.  It connects to EE LTE, the access point is applied, but no data is passed to the PC.  What's the last step to make this a success?
Attached is the profile from an AT command tester and the view from Windows showing we have connection?  Why no data... What am I missing!
Thanks!!
Ali_A
Do you have any ethernet cable plugged in to the ethernet port @ChrisMinto?
If so can you unplug it and then try to browse internet?  If not, try and disable the ethernet port temporarily.
From your images it looks like the PC is trying to connect through the ethernet port rather than the USB modem, even though you have set it as default.
Ali
26 REPLIES 26
Can't read that. Post just the page with the APN settings. I think I can just see the APN name.
Thanks @XRaySpeX , the APN details I've used are:
  • Name EE Internet
  • APN everywhere
  • User eesecure
  • Pass secure
  • Authentication PAP
Appreciate the help.
Looks OK!
Yes! And it reports the APN is applied (which it doesn't if I mod it).  So why no internet? Is there something special EE need to do if it's not one of their modems? Or is there another step I need...
@ChrisMinto : No, you can put an EE SIM into any mobile router.
Perhaps post those 3 pix individually & bigger & I might be able to see them & glean something.
Sorry - I see you can't zoom in - here they are individually - the AT tester is the key one I think.
Screenshot 2024-12-15 183314.pngScreenshot 2024-12-15 171627.pngScreenshot 2024-12-15 171535.pngScreenshot 2024-12-15 170713.png
Still no success - spoke to the hardware manufacturer Teltonika who suggested that some providers placed the connections in a "private network"  - the problem appears to be SIM side.
Any suggestions?
Try retyping the password and then changing the IP Type to IPV4 to see if that changes anything?
chistery
