on 23-11-2023 07:17 PM
My ee 5g router has had a green power light, but a red network type and red internet light on all day, I have unplugged, turned off, took the SIM card out and reset the router loads and nothing has changed
on 24-11-2023 08:56 AM
Hi @Llayton2001,
Are you still seeing the same issue this morning?
Do you have an EE phone? If you have, is that having any connection issues?
on 27-11-2023 03:44 PM
Yeah I’m still getting the same issue, I have an ee SIM card in my phone as well and that is working perfectly fine just the one in the 5g router isn’t working
on 27-11-2023 06:49 PM
Hi @Llayton2001,
What happens if you switch SIM cards between your phone and router?
Do you get service on either?
on 27-11-2023 06:54 PM
If I put my phone sim in the router, the router works but if I put the sim from my router into my phone, my phone says no sim
on 27-11-2023 06:58 PM
Thanks for confirming @Llayton2001
That rules out a fault with the router itself. The issue must be SIM or account related.
Please get in touch with Customer Care so a member of the team can take a quick look at your account.
They'll be happy to help. 🙂
on 27-11-2023 09:08 PM
Is it on contract or PAYG?
