on 23-05-2026 05:06 PM
How do I link my device to my account online?
it is a mobile dongle, but it sends a pin to the mobile number to verify but I can’t access the message on a dongle?
Solved! Go to Solution.
on 23-05-2026 10:51 PM
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found on a label on the outside or under the battery cover.
on 23-05-2026 09:15 PM
Most mobile routers can receive texts & reply to them. Login to it & look for the SMS Section/Inbox.
on 23-05-2026 10:30 PM
Thanks,
how do I log into the device?
