Data only plans for home Fixed Wireless Access
sgntuk
I'm looking to switch to EE from a different network, but I'm having trouble finding a suitable plan for my situation. I need a home broadband SIM to use in my own existing 5G antenna/router/gateway which is mounted outdoors on the roof. Due to local geography, the indoor routers EE provide aren't suitable, so I need a SIM-only plan I can use with my existing hardware.
I need a plan including:
  • 5G
  • Unlimited data
  • (Data-only, ideally)
  • Uncapped speeds
  • Suitable for home broadband, ie no practical limit to the number of devices on the network.
Looking at the Ts&Cs, both the ordinary SIM-only plans and the tablet & dongle plans specify a 12-device limit before services are capped or terminated.
Is there a more suitable set of plans I should be looking at, or can anyone with a similar setup recommend a plan?
I'm a personal/home customer.
The 11 device limit is for personal use only. If you need more you should be looking at a business plan.
