Data Roaming Add-on
RussellZ
Hi
I have looked on My-EE but can't find the link to buy data roaming add-on.  Can you point me in right place please? Russell
12 REPLIES 12
Are you on contract or PAYG? The Roam Abroad Pass is only for contracts.
RussellZ
I have a contract. It is data only on a mobile Wifi device,
(sorry for delay - thought I sent this last night!)
Text ROAMING PASS to 150 from it.
RussellZ
Thanks but with respect it is just a mobile wifi device. I don't have a text facility.
Any other sugggestions?
With respect most mobile routers do do texts. Does it have an envelope LED on it?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then look for the SMS section.
Wow! Every day is a school day!
I will try that now.
Many thanks
RussellZ
Tried several times but keep getting this message...
The connection has timed out
The server at 192.168.1.1 is taking too long to respond.
It may be a diff IP. The label on it should tell you.
Have checked label inside wifi device it confirms same IP address.  Tried again. Same result.
