Connecting to my mobile broadband router
Jud8
Hi, trying to connect desktop and Android phones to new 4g router. The WiFi is visible but won't connect.
6 REPLIES 6
Have you supplied your devices with the router's WiFi pwd when you try to connect?
Thanks for your email. Yes. We have the internet working now by plugging
the router into a desktop but the WiFi isn't working.
Warm regards
xxxxxx xxxxxxx
+xx (x)xxxxxxxxxx
[Mod edit: Please do not post personal information on the public board. Thanks!]
James_B
EE Community Manager
What happens when you try to connect via WiFi @Jud8?
IP configuration failure.
Warm regards
xxxxxx xxxxxxx
+xx (x)xxxxxxxxxx
James_B
Hi @Jud8,
Which router are you using?
@Jud8 IP configuration failure.
As long as you know both your Default WiFi and Router Admin Access Passwords (just in case), I would do a Factory Reset on the 4G MiFi Device.
