16-05-2024 05:01 PM
Hello,
We have just switched over to a EE 4G router due to poor BB connection down copper wire (3 miles from the box!). All devices connect fine, apart from Sky Q box. It says it is connected but there is no Internet connection. What can I do, please?
09-10-2024 03:05 PM
@Jennifermo Ah ok just wanted to check, is it only the Sky Q connection that drops, other devices still connect fine at the same time?
@MaryGunn Welcome to the EE Community
The following instructions should help with setting your connection to IPV4
1. When connected through your router, load the admin page at 192.168.1.1 in your browser (password will be on the back/bottom of the router or on the keep me card.
2. Select Settings and then find the profile section, usually this will be under Setup> Profile management
3. It will show the current profile in use, click New to create a new profile
4. Enter the following details to create a new profile. Profile name can be anything you like. Dial Number: *99# APN: everywhere IP Type: IPv4 Username: eesecure Password: secure Protocol: PAP
5. Click Save and then Set as default on the new profile.
Hopefully that will help with connecting your EE 4G router to your Sky Q box.
Alex
09-10-2024 05:37 PM
Good afternoon. I can confirm that SKYQ and the SKY Puck does work with the EE4G router. Can you please advise which "model" is on the underside label? Is it the HH10E? This has been validated for interoperability. SKY have optimsied their devices with their BB routers, but i can confirm that it's fine on EE MBB products. Kind regards
09-10-2024 05:59 PM
Hello yes, the Sky Q box has been the ongoing headache since we got this router. To be fair it's never delivered the connection speeds or coverage we were led to believe it would (ie, excellent) but we've invested in an external antenna and WiFi extenders that have helped enormously but the Sky Q box and the unstable connection remains an issue
10-10-2024 11:53 AM
Yes, that’s the model I have - the HH10E, but it doesn’t work out the box for various things
I had to follow the instructions to only operate over IPv4, and then it would connect to the Sky Q box.
Other applications also don’t work - I use ZScaler to connect to various tools with my work. I don’t get service unless using IPv4
Other observations with my EEHub is that occasionally the internet will drop out for all devices. I know it’s not a network problem, as my Phone is with EE and it’s 4g works fine. The fix is I have to restart the router, but that is very disruptive to everyone in the house, and it happens frequently (every other day!)
Any advice would be appreciated. I don’t want to simply reset the router, cause that resets my IPv4 configuration, opening up another set of problems!
Thanks,
Will
10-10-2024 12:47 PM
Hi Will. I’ll get a colleague to reach out to you via the correct channel. One of the team can review some of your challenges that you’re facing and try and reproduce the issues you’re highlighting and provide some feedback. I’ll check with someone on the process.
kind regards
