16-05-2024 05:01 PM
Hello,
We have just switched over to a EE 4G router due to poor BB connection down copper wire (3 miles from the box!). All devices connect fine, apart from Sky Q box. It says it is connected but there is no Internet connection. What can I do, please?
16-09-2024 07:50 PM
Fixed it!
Solved the issue by changing the router settings, and updating a setting to use IPv4 instead of IPv6
17-05-2024 10:08 AM
Hi @Judi8
Welcome to the community.
It sounds like the router is working correctly, since you're able connect and use your other devices. I'm not familiar with Sky Q, but is there a way to test your connection?
16-09-2024 02:05 PM
I have exactly the same issue! I called up sky and they suggested it might be incompatible. I’m hoping there is a router setting I can update, but haven’t found it yet!
16-09-2024 06:23 PM
Which router are you using?
Do you have other devices connected?
Leanne 🙂
16-09-2024 07:50 PM
Fixed it!
17-09-2024 11:52 AM
Hey @Williamglasse
It's great to hear you've got this sorted, thanks for getting back in touch to let us know.
Debbie 🙂
08-10-2024 09:14 AM
Hi, are you still connected? I've had this problem on and off for years. It connects for a while then drops off and won't reconnect for ages. My contract with EE has expired and planning not to renew it because of this issue.
08-10-2024 12:40 PM
Hi @Jennifermo,
Welcome to the EE Community
Have you managed to change your router connection to IPV4 as @Williamglasse suggested worked for them?
Alex
09-10-2024 09:35 AM
09-10-2024 01:08 PM
How do I change that please? Troglodyte here!! Thank you.
