Change password on 4G mobile box
VicCam
Hi Community, literally pulling my hair out trying to find where to change my password??
I have tried the http://192.168.1.1 but it won't let me open the page.
I don't want to change my admin password or logging onto to here, it is so visitors that come to the house can have a easy password rather than the one on the box.
V
8 REPLIES 8
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
VicCam
thanks but I typed
"I have tried the http://192.168.1.1 but it won't let me open the page."
So it won't let me open the page - I don't know how else to change it ?
Do a hard reset & then try again.
Have now tried hard reset, even switched the box off overnight and still not being bale to login to the address http://192.168.1.1 I can't use the wifi and want to launch the box out the window now as I can't speak to a human at EE or even a chat function on here ....someone send help
Try calling CS on the Freephone no. (Opt. 2) in my sig.
VicCam
So if anyone is reading this, can I confirm that once you reset your box, the password goes back to the original password on the box!
Therefore if you need to change, so a box reset and it goes back and I shall keep that and print it in large and stick it on my fridge for all to see
James_B
EE Community Manager
That's right @VicCam, a factory reset will return the WiFi password to the default password that originally came with the router.
Yes, that's the case for all routers but it shouldn't prevent you opening the http://192.168.1.1  page even if you can't login there.
