09-04-2023 05:38 PM
So I've already got a contract for an iphone 12 + unlimited data so I was wondering if I could order another sim to put in a mobile hotspot wifi hub and if that would work,
having my phone and hotspot hub active at the same time on the same sim
09-04-2023 06:29 PM
Yes, you can buy another SIM with a new no. to put in your mobile router, but you can't have 2 SIMs on the same no. You order the new SIM as an additional line to get 10 % off it.
10-04-2023 02:34 AM
Thanks for the quick response!
Okay so would it then be fine for me to put my current sim from my phone into the router, sure I won't be able to receive calls or texts but there are certain times at the moment where I desire better speed / connection.
10-04-2023 03:10 AM
You may put your phone SIM into any device. You probably can receive & reply to texts on the mobile router but may not be able to send texts directly.
