on 08-04-2023 07:25 PM
Hi we have just set up the 4G router for home Wi-Fi and whilst it works fine with a couple of devices (mobile phone/Alexa) once I try to add the TVs to stream Netflix etc we are not able to play without the service being really slow. Is there a way to ‘boost’ the connectivity around the home or resolve this issue? Many TIA for any advice or support
09-04-2023 02:49 AM - edited 09-04-2023 02:49 AM
What does www.speedtest.net tell you about your Internet Speed.
on 09-04-2023 08:03 PM
on 09-04-2023 08:18 PM
If you are streaming in 1080P-HD, that can use half your available speed, that leaves 5Mb/s for all your other devices to share.
on 10-04-2023 12:15 AM
The speeds you are getting are adiquit for Online Streaming, Netflix can sometimes be a funny over the way it Streams over IPV4/6, within the Routers Admin try setting up a New APN Profile and Saving it as a PAP Authentication and for IPV4 Only.
