Balance and top up
sizzlermark50
This may sound incredibly dumb but I've bought a mobile broadband and prepay sim .....How do i check the remaining balance and top it up ?? What am i missing ??
Visit http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see your data & credit status as well as its mobile no. at the top.
Use Fast Top Up online with a UK bank card. You don't need to login or register anything. All you need is your mobile no. & it doesn't remember your card details.
@XRaySpeX As far as I can see on the Fast Top Up page, you can use not only a UK card but also cards from other countries for topping up. Even those that are not on the drop-down list when manual entry is enabled. Is that correct? Thank you for your response!
@Dmytro75 : If the card works then use it; otherwise call CS.
