Arlo Security Camera and 5GEE Router
mark_12
I've just switched from ADSL to 5GEE home broadband and facing some issues getting my Arlo security cameras to work.
There are 2 cameras which connect wirelessly to an Arlo SmartHub which is connected to the 5GEE router via ethernet cable. The issue seems to be that every few minutes the connection is lost resulting in the cameras going offline and then coming back on. All other devices connected are remain connected and all seems stable. The signal strength doesn't look to be an issue either.
I've had a search around the community and it seems others have had similar issues but I can't see a clear solution - are there any settings I can change to prevent the connection from dropping off? I've seen CGNAT being mentioned a few times but I'm not too sure what that means or if it should be adjusted.
Would be a shame to have to return the product as speeds are far greater than what I was getting previously however if I can't get the security cameras to work I'll  have to 😥
Any help is greatly appreciated!
13 REPLIES 13
mark_12
Hi, did you manage to find a solution to this? I've just switched to the 5GEE router and getting the same issues when connecting the Arlo SmartHub to it.
mark_12
Hi, don't suppose you could share how you got the Arlo cameras to work with the router? I've just switched to 5GEE from adsl and the Arlo SmartHub disconnects every few minutes.
Thanks!
jwDave2
Largely the issue is resolved, it was down to the EE mobile signal. EE did some work in the mobile mast nearby and the issue mostly went away.
Ah ok thanks! Signal strength is strong and all other devices remain connected so I’m not sure that’s the issue for me…
Christopher_G
Hi @mark_12
Welcome to the community.
CGNAT means that you don't have a fixed IP address, it can change, which can sometimes cause problems with devices that aren't designed to use it.
A fixed line broadband connection would definitely be more stable and compatible with a wider range of devices.
Ah ok, thank you for clarifying!
Is it possible to create a fixed IP address or is that just how 5G internet/routers work?
Christopher_G
Our Mobile Network only uses CGNAT, @mark_12, there isn't an option to change it to a fixed IP. That's something your get with our Home Broadband packages.
Thank you. Perhaps returning to a fixed line is the way then 😣
You don't get a static public IP on fixed Home BB either but at least the dynamic public IP you do get is not shared with others.
