SMS in 5g ee ruter
takana
It is only able to receive sms via 4g network. Is it possible to receive sms via 5g?
1 ACCEPTED SOLUTION
Christopher_G
Hi @takana
Welcome to the community.
Your SIM card can use both 4G and 5 signal. As @Doge correctly said, the SMS and calls will go through on the 4G connection.
Doge
Valued Contributor
Valued Contributor
5G is only data and cannot do SMS or calls. That is why phones using 5G use more battery as they have to maintain two active aerials. You need a 4G sim for SMS/calls
Christopher_G
Hi @takana
