5g ee router has red power light constantly on
Wakey3333
I have rebooted my 5g ee router, it is about 9 months old, and I haven't had to use it recently so not sure when it stopped working, but I tried also to do a reset using the usual tool, on the underside of the 5g ee router but no change to the situation.
The blue lights being on for the network type, and the globe icons, green light for the wifi/wps however the power light is constantly red and the network does not appear in the list of wifi networks available to me.
Any ideas what to do next, as I am not sure what to do and the help community I can't seem to find anything similar.
Has it a PAYG SIM? If so, Sounds like your PAYG SIM has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
Wakey3333
Thank you, that sounds exactly like the problem! I'll give them a call and try to reactivate it...that's a bit of a cheek given how much I pay each month for it and the fact the CPI increase added a load onto the price too!
If you had a CPI increase it'll be on contract, not PAYG. So hibernation is not the answer!
Back to the drawing board....
Katie_J
Hello @Wakey3333.
Thanks for coming here.
Please get in touch with our technical care team who will help run a full diagnostics on this for you.
Katie
