5g NR5103 Router - Unlocked branded 5GEE
baki1
Hi, I have a NR5103 with is 5GEE branded, but unlocked. I can use with other networks, but would like ot put the firmware to the standard Zyxel. How can I install the firmware? There is no option in th 5GEE settings to allow me to select a firmware version - it only allows online download of the 5GEE versions
12 REPLIES 12
Christopher_G
Hi @baki1
Welcome to the community.
You may get an answer from another community member, but that isn't something that we can support you with.
Northerner
Hi @baki1
You cannot as the software/hardware is designed for EE.
If unlocked you should be able to use another sim but the software will be EE.
You could always try contacting Zyxel and they might be able to help.
baki1
practically nothing can be done with the firmware (E).
no cell lock, no band lock @Northerner
Здравствуйте, zyxel может обновить устройство до своей родной прошивки?
@SKYFF wrote:
Hello, can zyxel update the device to its native firmware?
infinitywaiter
Prodigious Contributor
If you did a simple bit of research yourself, then you would come across the Zyxel page where this is discussed in full.
Do a simple search for 'Zyxel Community 5g nr5103 Router re-sold by EE in UK'
On that page is instructions for setting a new APN so that you can get off the EE profile and links for flashing the default firmware, however you do that at your own risk of bricking if not done correctly.
I do not subscribe, so please do not always expect a reply.
@infinitywaiter : Who are you addressing? It's not clear!
Please use the Reply button on the post itself of the point you are replying to so as to maintain the linkage.
Ссылочку пожалуйста на тот пост
@SKYFF wrote:
Link to that post please
