5Gee router 2021
Byronmatthews77
Can someone confirm that this is just plug & play with a sim and doesn’t require any engineers etc?
@Byronmatthews77   It’s plug and play no engineer required.
EssexBoyEE
Technically its Plug and Play, but for best results depending on where you live and the EE Coverage you get, its best you spend some time to position the Router (out of the Box) in various positions around the House ie, Upstairs / Downstairs, Window Sills, North / East / South / West of the Property etc, in order to get the best Signal Reception from EE and the best WiFi Reception for your Devices etc.
The above is something you can do yourself, should be a one time set up and certainly doesn't require any Engineers to visit you.
No engs are ever used for mobile BB (unless you are paying for an antenna to be fitted); they're only employed for fixed BB.
