22-03-2023 02:54 PM
I'm having to reboot my 5G router a couple of times a day as it intermittently loses internet connection.
Following a reboot all is well until the next time.....
I've had the router for about 6 months and it's been very reliable until now, I haven't physically moved it or many any config changes.
Any suggestions?
Phoning 150 just gets me (eventually) to the automated service that checks my line (surely my mobile phone line, not the router) and then hangs up. Arghhhh
19-05-2025 05:51 PM
so should everyone with this same issue start anew thread so we have hundreds of threads with the same issue? Or should we look through the existing threads that are marked as "solved" to find a solution that has worked for others, as I have done.
19-05-2025 06:07 PM - edited 19-05-2025 06:13 PM
@grimo : You should do both. "Same issue" hardly ever is. In this instance there could be many reasons for the bland "loses internet". For starters you don't know if you have same router as OP. Better to have your own thread dealing only with your own issue & targeting your specific circumstances. And the same goes for the other hundreds - 1 of users with the seemingly "same issue".
20-05-2025 08:45 AM - edited 28-05-2025 01:27 PM
Hi @grimo,
Welcome to the Community!
If you could let us know some specifics of the trouble you're having then we'll be happy to offer some advice of how to help. Alternatively, you can give our team a call, and they'll be happy to support.
It is also worth checking our Community Guidelines so you can find out how solutions work, as if someone feels their issue has been resolved then they are able to mark their post as solved, even if other users might be having similar issues.
Rach
20-05-2025 09:35 PM
This is not a solution. Garbage company
